chevy blazer key fobdawngeisler 12-16-2004, 03:54 PM I have a 2000 chevy blazer, just purchased a key fob, any suggestions on how to program it? Thank you 2octops 12-24-2004, 02:38 AM With the driver door closed, hold down the power unlock button on the door panel. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode: Locking the doors Unlocking the doors Important All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated. Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner: Locking the doors. Unlocking the doors. Repeat step 7 for each additional transmitter. Turn the ignition switch to the ON position in order to exit the transmitter programming mode. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
