1998 Silverado driver side noise - please helpsoda 12-12-2004, 06:01 PM Hi, I have a 98 Truck 5.7 liter. About a month ago I took it in to have front brakes put on. A few weeks later I begun to here rattle and grinding noise from the drivers side when making turns and going over bumps. Very obvious noises when making right turns at slow speeds. Well I have taken it back to the mechanic several times. He finally came to the conclusion that it was the lower ball joint. Well, after paying $400 to replace both upper and lower joints noise is still there. Before this I thought it might be something with the caliper but he tried replacing that and the noise was still there. He is willing to give me a refund, but I really just want it fixed. Any help would be much appreciated. Sounds like something is loose when going over bumpy terrain. When making right turns at slow speeds you here a kinda of grinding noise. Thanks buttnekked 12-12-2004, 06:34 PM check your wheel bearings. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
