Cam Question.
GrayV
12-11-2004, 12:15 AM
Okay....
I'm sure this question is here in the archives somewhere but I didn't see it.
I want to replace my cam shaft with a skunk2 and was wondering if there are any major problems associated with the switch.
Coming up soon it is time for a new clutch/ timing belt/ water pump so I was going to purchase the cam shaft and have it thrown in while it is there.
Is this a good idea or should I leave it alone?
I already have the header, cat, & cat back in place so I am hoping I will see a big difference.
Thanks!
honda_luvr_2000
12-11-2004, 03:11 AM
well if it's a stage 1 cam, u should be ok w/ the stock valve train. however it'd be a real good idea to get an adjustable cam gear to go w/ the cam. that'll let u get the best result out of the cam. it would be a good idea to thro on an intake too, if u don't have one already (didn't mention). if u restrict the incoming air, there's no point in having no restriction going out.
~ls/vtec~
12-11-2004, 04:52 AM
dont forget about floating valves with an agressive cam. if its stage 3 then its really recommended to get springs and retainers. even if ur not revving it past the stock redline
GrayV
12-12-2004, 02:18 AM
AEM V2 intake
unknownluder69
12-12-2004, 10:36 AM
just tell let u know the afore mentioned aftermarket 'upgrades' will not give u a significant increase in power I/H/E maybe aroiund 5-7hp new catback maybe around 1-3hp so u know ur not goin to be slammed in the back of ur seat with those. U might also want to look into a new flywheel if ur going to get a new clutch and maybe new pulley system. but thats just my opinion.
Ricochet
12-13-2004, 12:52 AM
A Skunk 2 cam will give you hardly an increase in performance, especially on a non turbo d-series. You'll definitly feel it a little, but will still get stomped on by family sedans. Save the money for boost.
