How to tell if it is a posi trac????
2shus
12-09-2004, 10:22 PM
I have a 91 F-150 2wd with bix 6 cyl and a 5 spd. I was wondering what is the best way to tell if it is a positrac rear end or was it an option that year. If you raise both rear wheels and it is a posi what will the other wheel do when you spin one? Thanks.
mule38
12-09-2004, 10:36 PM
I had a friend with a ford that had a positive traction rear end and it made a wining noise when it took off.If I am not mistaken I believe that both wheels would turn the same way if you lifted them off the ground and turned one side by hand.
dougger222
12-12-2004, 08:58 AM
There should be an axle code on the door jam area. I know both the F250 and Excursion have a code.
The truck is single the suv is dual.
