removing the fan in a '96 4.0 . . .HOW!!
josepi63
12-09-2004, 03:28 PM
I've decided to enter the water-pump changeing nightmare and have taken a break to regroup.
I need to remove the fan (not the electric one). How do I do it?
Dale Aeppli
12-09-2004, 04:51 PM
If you're reffering to the clutch assembly Remove the 4 bolts where it bolts to water pump. dale jeepman600@aol.com :2cents:
josepi63
12-09-2004, 05:38 PM
Dale,
Actually, the fan isn't attached directly to the water pump. It is connected via serpentine belt from a pully on the fan shaft to the water pump pully. However, there are 4 blts holding a flange to the pully. If I remove those will it come off? There is a viscous pump on the other end (toward the radiator). I'm not sure how all that works.
Thanks for the reply
Dale Aeppli
12-09-2004, 05:51 PM
Dale,
if you remove those 4 nuts from flange the whole assembly should come off. dale holler at jeepman600@aol.com i have different diagrams that might help you out
josepi63
12-10-2004, 03:34 PM
I changed the thermostat successfully!!! Thakns for the help, Dale.
Only problem is now I have coolant leaking from the thermostat housing gasket because I moved it. It's also blowing cool air. Hopefully, when I change the thermostat and asket it will cure all that
