1986 Caprice Rear Brake Conversion
wolverine702
12-06-2004, 01:41 PM
Are there any GM B-Body cars with rear disk brakes that can be used to convert a 1986 Caprice from rear drums to rear disk brakes? I know you can purchase a kit from Stainless Steel Brake Corp, but it's pricey at $710.00.
This caprice also has the stock 3.08 rear end gears. Are there any GM cars with taller gears that would fit a 1986 caprice?
CD Smalley
12-06-2004, 10:11 PM
1994-96 Impala SS and 9C1s both have rear disc and 3.08s as a general rule.
TommySS
12-08-2004, 07:10 PM
CD Smalley is correct. The B-body driveline is essentially the same. The 9C1/SS packages are the same as the station wagon.
However, those are different from what you'd typically find on "regular" B-body sedans.
I'd source a salvage yard. Be sure to include the master cylinder and proportioning valve to match the disc brake setup. Be careful.
CD Smalley
12-08-2004, 09:07 PM
No need for the valve. GM didn't change that either.... cheap @#$%@s.
I don't think you need the master cylinder either. You'd be better off using and adjustable proportioning valve.
1968 Pontiac
05-20-2006, 11:06 PM
I'm doing the rear disc brake swap on my 91 Caprice. It would seem from the replies, that this should swap right in, or will I have to deal with speed sensor issues? The donor diff is from a 96 police cruiser with 3:23 gears and posi. I know the parking brake cables are different at the rear caliper vs. the drum. I haven't picked up the new to me diff yet, so I didn't have a chance to check what the 96 diff has for calipers, but I also have a spare set of brackets, calipers, rotors etc., that were donated from a 94 taxi. I noticed the calipers were PBR brand. Is this standard? Thanks.
