Air Pump not working - 1999 BlazerJSweeneyNJ 12-06-2004, 12:16 PM I wrote before saying I failed inspection due to emission codes 0410 & 1415. Just heard from mechanic at dealer's. Says Air Pump not working and needs to be replaced along with 2 valves and a hose. Cost with parts and labor - $540. Is this in-line? Also, said noticed oil cooler lines lines(both upper & lower) are leaking. Cost to replace lines - $375. Again, does this sound right? Or have they seen a sucker coming?? Thanks J. TonyMazz 12-06-2004, 02:38 PM I wrote before saying I failed inspection due to emission codes 0410 & 1415. Just heard from mechanic at dealer's. Says Air Pump not working and needs to be replaced along with 2 valves and a hose. Cost with parts and labor - $540. Is this in-line? Also, said noticed oil cooler lines lines(both upper & lower) are leaking. Cost to replace lines - $375. Again, does this sound right? Or have they seen a sucker coming?? Thanks J. Well it appears from AllData that to replace the pump with OEM parts is around $178 bucks and about an hour's labor... Then throwing in the hoses is another 1.5 hours....... FYI there is a technical bulletin on the P0410 code Check Engine Light On, DTC P0410 Set (Replace AIR Pump, Install New Hose Assembly) Models: 1999-2003 Chevrolet Blazer, S10 1999-2001 GMC Jimmy 1999-2003 GMC Sonoma 1999-2001 Oldsmobile Bravada with 2.2L or 4.3L Engine (VINs 4, H, 5, W - RPOs LN2, L43, L35) Condition Some owners may comment on the check engine light being illuminated. Upon investigation, the technician may find a DTC P0410 indicating that there is a concern in the secondary air injection system. Cause Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump. Correction Replace the AIR pump and install a new inlet hose and solenoid tube assembly using the following procedure: 1. Prep vehicle. 2. Raise vehicle on hoist. 3. Remove shield covering AIR pump. 4. Remove hose and vacuum lines from pump and solenoid. 5. Remove AIR pump inlet hose. Do not re-use. 6. Disconnect electrical connectors from pump and solenoid. 7. Remove pump mounting bolts and pump. 8. Transfer isolators from the old pump to the new pump. 9. Install new AIR pump and bolts to vehicle. Tighten Tighten the bolts to 17 N.m (12.5 lb ft) 10. Route new hose assembly up between engine and fender. It should come up near the area between the battery and the coolant bottle. 11. Connect new inlet hose to pump inlet. 12. Connect old outlet hose to pump outlet. 13. Connect electrical connector to pump. 14. Connect electrical connector for solenoid to connector on the new hose assembly. 15. Connect the hose with the white nipple to the vacuum source hose. 16. Connect the remaining hose to the shut off valve. 17. Install shield covering AIR pump. 18. Lower vehicle. 19. Remove coolant reservoir nut nearest the battery. 20. Route new hose assembly between the battery and the coolant reservoir with the solenoid on top. 21. Install the solenoid bracket onto the coolant reservoir stud and reinstall the nut back into the vehicle. 22. Use a wire tie to keep the new hose assembly away from the engine. On four cylinder engines, tie to the AIR outlet hose. On six cylinder engines, tie to an available hole in the radiator fan shroud. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
