Where is the EGR Valve locatedtanjames2001 12-06-2004, 02:31 AM I have a 96 Toyota Camry v4 , i would like to know where is the EGR Valve located , i think my valve is clogged . James gator2764 12-06-2004, 07:40 AM It should be right behind the valve cover against the fire wall. It will have a metal tube that comes from the intake and a few vacume lines. It can be cleaned with carb cleaner. How many miles do you have? burchard 12-06-2004, 11:44 AM Go to my gallery and loot at pic pport_5SFE . The round valve behind the tubes is the EGR valve. tanjames2001 12-06-2004, 05:58 PM It should be right behind the valve cover against the fire wall. It will have a metal tube that comes from the intake and a few vacume lines. It can be cleaned with carb cleaner. How many miles do you have? I have about 152000 miles on my car. tanjames2001 12-06-2004, 06:09 PM Go to my gallery and loot at pic pport_5SFE . The round valve behind the tubes is the EGR valve. Thanks for sharing the pic , i have a camry 152000 miles on it , after cruising in the freeway , and i took an exit , when i reach the traffic light , my engine became unsteady and died off , after a few minutes , everything is back to normal , this happened a couple of times already. burchard 12-07-2004, 10:19 AM Thanks for sharing the pic , i have a camry 152000 miles on it , after cruising in the freeway , and i took an exit , when i reach the traffic light , my engine became unsteady and died off , after a few minutes , everything is back to normal , this happened a couple of times already. Sounds like dirty EGR, clean it and , probably you problem will be gone. smittyflys 12-08-2004, 07:37 PM Here is a good link explaining the ERG system. In trouble shooting, you may have to replace the modulator, or the VSV. http://www.autoshop101.com/ go to tech article #61. Good luck heathershonda 03-12-2005, 07:05 PM Is the egr valve in the same place on a 2000 model? I have to replace it on mine. Is it hard to do? Automotive Network, Inc., Copyright ©2013
