Turbochris and mandy 12-05-2004, 03:46 PM i got a 96 neon. i am custome making a turbo kit for my car but i have one problem , i dont know were to get the oil line to be able to get the oil up to the turbo. the rest i pretty much got down so if anybody knows let me know asap. NEONS ARE BAD ASS :) DanF 12-05-2004, 11:40 PM You can fab your own lines out of silicone tubing... it can handle like 600+ degrees and I think 100 psi... it may not be quite that much but I know it will exceed what you need by far... you can buy it from www.bakerprecision.com you can just get a line start and put it into your oil pan, drill it yourself if you want, then put the silicone tube into the oil in, then habe it come out and dump back into teh engine the same way, either into the oil pan or the valve cover. You can use an external oil pump to push the oil through just have it set to some on when the car turns on. I know some people who have done it like that. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
