Coolant Leaking Out!
Google
Web AF
ga81peach19
12-03-2004, 01:12 PM
I have a question..I have a 91' Chevy Cavalier that I just purchased not to long ago and I am already having problems:
Main Problem:
Everytime I start the car it starts jerking, unless it is driven for a certain amount of time, then the radio and winshield wipers wont work until the car heats up (I guess) then I can turn the car off and restart it and they will work. But my main problem is everytime I drive antifreeze leaks out of my car and causes the temperature gauge to go all the way over. I got a hose (dont know which one) changed and it still leaked. I got some radiator stuff to try and plug it if there was a hole inside and it worked for a few days then i was driving and the temp went up and the hood started smoking. Someone looked at it and sd it wasnt leaking from the radiator hose (or whatever) ..but it is a hole somewhere under the hood and it leaks after being driven.
Question:
Could anyone suggest what I should do or might know where the leak is coming from? Is this a water pump or thermostat problem?
GMMerlin
12-03-2004, 01:25 PM
You will need to have the system pressure tested to find the source of the leak
ga81peach19
12-03-2004, 01:35 PM
oh ok..so where can i get that done?
Classicrocjunkie
12-03-2004, 02:22 PM
your... : twitch: .... dealership.... or another good service shop thats non-comercial .... commercial is ( i.e. pepboys, monroe, e.t.c)
mattcurry
12-15-2004, 12:08 AM
sounds like a waterpump to me.
ga81peach19
12-15-2004, 10:31 PM
I found out my mats are getting soaked on the passenger side...I think the water or coolant (whatever) is leaking to the inside. What does that sound like?
public
12-15-2004, 11:02 PM
That would be from the Heater Core. The little plastic tubes on them crack.
ga81peach19
12-28-2004, 09:18 AM
where is the heater core?
public
12-29-2004, 04:37 PM
Under the dash. Center of the car.
Google
Web AF
