Re-wire repeators???
KidDragon
02-28-2002, 03:02 PM
How do you re wire your repeators to stay on when the lights are on???
poppy_morenito
02-28-2002, 05:36 PM
WOW .. I wish I was brave enough to try that. I need Pictures or something .... Cool Idea
Swonder67
02-28-2002, 05:56 PM
do you want them on all the time, then blink when you hit ther blinker, if you want that, you need a relay... If you just want them on all the time... all you gotta do is take out the sidemarker, and cut the positive source wire. (the wire that's non black.) now the fun part, take off the corner light, take a coat hanger, and and bend it so it's straight, and stick it in the fender wellthrough the hole the corner light you took off. if you wiggle it around a bit, it should pop out the whole the sidemarker came off, then get a long piece of wire, attach it to the wire you just cut off the sidemarker, and tie the wire to the coat hanger, then carefully pull the coat hanger back out, and the wire should come out with it, then just splice it onto your parking light bulb.
