2000 sunfire bright light problem
Google
Web AF
mazer
11-30-2004, 07:50 PM
Sunfire has been great 145,000 and only replaced belt and brakes. Went to put car into gear and daytime lights blinked 10 times. Went to put on bright lights and lost all headlights. Any similiar problems and heard any solution to this. Don't want to take it in if minor or really expensive.
mattcurry
12-13-2004, 12:01 AM
Multifunction switch - i think it's located just in behind the glovebox. Had tonnes of cars with that problem through the shop, and that's what it was every time, except for one, which had a bad relay
mazer
12-13-2004, 12:52 AM
i will give that a shot, thanks
Natebomb
12-13-2004, 10:42 AM
Any Success?
red00sunfire
04-20-2005, 10:24 PM
My daughter has a 2000 sunfire. Had same clikking noise coming from the relay. Did it for me once and DRL's came on. Days later no such luck. DRL's and high and low beams INOP. I replaced DRL relay, no change. Can someone give my details on malfunction swith.
johnmk
09-25-2006, 05:56 PM
I got 2000 Pontiac Sunfire GT.
No DRL or high beam on the right side. Checked everything, wiring, fuse boxes, relays, switches etc. Had to take front light, battery and air filter to check another relay.
It is either low on both, or high on the left side only. Still trying to figure it out.
Cavalier2000
09-25-2006, 06:01 PM
you probably just need new blubs, when they go out the blink several times to let you know that one is out, it might the the highs on both bulbs
johnmk
09-26-2006, 01:17 AM
I got new bulbs. The problem is, there is not enough voltage (power) coming in to the right light. It is enough for low but not high. It is a common problem with sunfires. Some people just shorten two yellow wires in the front relay, some just bypass the switch box...
To be continued
Google
Web AF
