2002 sierra 4x4 grease fittingssselley 11-29-2004, 10:12 PM Any help on the number/location would be appreciated, I want to make sure I get them all. Also, how much grease should be "squeezed" into each fitting? Thanks... 2000CAYukon 11-30-2004, 06:23 PM I have a 2000 Yukon 4x4 and I think the front suspension is the same. Here is what I lube each oil change: Upper and Lower Ball Joints Inner and Outer Tie Rod Ends Idler Arm (there are 2 zerk fittings to grease!) Pitman Arm When adding grease you do not want excess grease to squirt out. I usually give the grease gun two pumps. Keep an eye on the rubber boot at each fitting. You should see it expand. If you overfill, wipe away the excess grease. I also replaced some of the fittings with angled ones so that it was easier to lube the front end. //2000CAYukon vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
