95 4x4 Blazer with W Engine Intmit Startingthunderstrike44 11-29-2004, 05:18 PM I have been running into a problem with my 95' Blazer in that it is intermit starting. I turn the key and the engine cranks but doesn't fire. I can turn it off and on maybe 20 times and no start. Then all of a sudden it starts normal and runs without a problem. I turn it off and try to start it 20 minutes later and same ritual. It starts anywhere from the first time to maybe 20-30 times of trying. I tried replaceing the Fuel pump relay (everyone kept telling me that was it) but it did not cure it. Any other sugguestion would be very welcome.... BR Fractured1 11-29-2004, 06:27 PM you might be looking into this...do some searching on your ignition switch...here's a post on the replacement...good luck http://www.automotiveforums.com/vbulletin/showthread.php?t=287636 BlazerLT 11-30-2004, 01:22 AM I have been running into a problem with my 95' Blazer in that it is intermit starting. I turn the key and the engine cranks but doesn't fire. I can turn it off and on maybe 20 times and no start. Then all of a sudden it starts normal and runs without a problem. I turn it off and try to start it 20 minutes later and same ritual. It starts anywhere from the first time to maybe 20-30 times of trying. I tried replaceing the Fuel pump relay (everyone kept telling me that was it) but it did not cure it. Any other sugguestion would be very welcome.... BR CPI Injector is shot. Search for CPI injector in the Blazer section. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
