Town & Country - no park, then no Reversejerryshenk 11-28-2004, 02:38 PM I think I have a problem with my shifter alignment. Yesterday, I parked, threw in into part and started to get out and realized it was in reverse. I messed with it a little and it went into Park without any problem. Later, I parked it and couldn't get it into Park at all so I parked it overnight in Neutral with the parking brake set. Went to church and came home a little after noon and now I can't get it into reverse. When I go through the gears now, the shifter goes down to low and then a gear lower than that. I think it's a problem with the shifter alignment but I really don't know how to adjust it or even if that makes sense. wuwei96815 11-29-2004, 11:55 AM I think I have a problem with my shifter alignment. Yesterday, I parked, threw in into part and started to get out and realized it was in reverse. I messed with it a little and it went into Park without any problem. Later, I parked it and couldn't get it into Park at all so I parked it overnight in Neutral with the parking brake set. Went to church and came home a little after noon and now I can't get it into reverse. When I go through the gears now, the shifter goes down to low and then a gear lower than that. I think it's a problem with the shifter alignment but I really don't know how to adjust it or even if that makes sense. You never mentioned in your post whether or not you had checked your transmission fluid level. jerryshenk 11-29-2004, 12:30 PM You never mentioned in your post whether or not you had checked your transmission fluid level. Yeah, I did check the transmission fluid. I even smelled it and it smelled ok....not that I know exactly what I'm smelling for;) GTP Dad 11-29-2004, 01:26 PM I agree with your shifter alignment assessment. It may have come loose at the transmission or the cable may have come loose causing the change. I don't think it is a problem with the transmission itself since everything seems to work. Take it to a tranny shop and have them look at the problem. Should only cost a few dollars to fix. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
