2000 Cavalier - Headlights out, clicking sound from dash fuse panelDocShock 11-28-2004, 01:08 PM I have a 2000 Cavalier and recently I noticed that my daytime lights and headlights were going out when switching the car into gear. The dash shows that the lights are on when in park, but when you put it in gear there's a "click click click click click" sound from the fuse panel by the drivers side door, which is followed by the service light showing on the dash panel and the headlights/daytime lights going out I had some wires and a relay replacef earlier in the week, but it started happening again the next day. I opened the fuse panel and gave the relay a light tap and the problem seemed to correct itself for a short time, but then occured again later. Could the relay they replaced be bad or might there be short or something? Thank you. mattcurry 11-29-2004, 01:55 AM %99 sure it's your multifunction switch. Seen that problem a thousand times through the shop. jable 01-01-2005, 06:33 AM I was having the same problem. One of my headlights was blown. Check them at all three levels, driving, low, and high. wiseguy01 01-03-2005, 01:49 AM just replace your drl relay and you will be fine or better to see if it is bad remove it. i have a 99 and i removed mine the little light in the dash just blinks and the service light is trying to tell u to change it. wiseguy01 01-03-2005, 01:53 AM thats the little black box in the fuse panel z24 fanatic 01-04-2005, 01:29 AM I own a 2000 z24 cavalier and i had the same problem with my headlights the problem turned out to be that the headlights were wrong for the car check your headlights and make sure they match what your car needs hope that helps. CATSMASHER 06-20-2005, 01:39 PM %99 sure it's your multifunction switch. Seen that problem a thousand times through the shop. WHERE CAN I FIND THE "MALFUNTION SWITCH" ON MY 2000 CAV. THANKS. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
