Tach Questionstreetrcr45 11-26-2004, 06:09 PM I just got a 2001 neon se today (paseo died :lol: , so its a step up :uhoh: ). I noticed that there was no Tach. I'm just curious, at (or around) what speed does each gear redline. Sorry if its a dumb question..but i just don't feel cofortable not knowing where i'm at on the tach. btw...its auto :rolleyes: the_game_rock 11-26-2004, 08:07 PM I got a 99 neon 5 speed it may be different but mine it a around 7 I believe I also had to put in a tach. The Rev limiter is at 7. streetrcr45 11-26-2004, 10:14 PM I got a 99 neon 5 speed it may be different but mine it a around 7 I believe I also had to put in a tach. The Rev limiter is at 7. ok, thanks..but i need to know what speed each gear tops out at... like 1st=40mph 2nd=70mph and so on...if someone could give me some information about that, i would be very appreciative DanF 11-27-2004, 01:11 PM Don't manually shift your auto.... its a chrysler... front drive.... your trans will die... quickly. If you really need to be that 1/10th faster leave it in 2nd till 80mph then shift into drive. All manually shifting an auto does is locks up the torqu converter and raises the trans temp and puts more wear on things. My ATX shifter at like 6000 in first at maybe 40 or a little higher, if I had it in 1st which I only did like twice, it redlined/limited at 6700 and maybe like 45-50 mph, second should redline around 80-85 and 3rd redline at 117 where the speed limiter is. But please, save your car and don't mually shift it. DanF 11-27-2004, 01:13 PM Mine was a 1st gen though. streetrcr45 11-27-2004, 10:33 PM thanks...i am not planning on putting it in first...i would just keep it in second...i just wanted to know cause i was in 2nd and i didn't know how far i could push it...thanx for the info though. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
