2000 sunfire heating problem
Google
Web AF
ias_rick
11-23-2004, 11:17 AM
00 sunfire was overheating so I changed the thermostate and now it barely heats up when driving and at a stop it heats to normal temp then goes down once it stsrts moving. It has the 2.2L in it
FormulaLT1
11-23-2004, 03:46 PM
Might be a faulty coolant Temp sensor.
hotbug1776
11-23-2004, 05:00 PM
that's the way they run, my 2.2L (when I had it) ran cold as well unless it sat. I changed the thermostat to try to correct the issue, but it still ran the same way, so I didn't mess with it any more.
intimidatorjr20
12-02-2004, 12:01 AM
If you change the thermostat, be sure to use a GM part, as the aftermarket t-stats have a weak spring, which lets it open even though the vehicle is not up to temperature. My wife's car had the same problem. Hope this helps.
Google
Web AF
