2001 Tracker door handle removalJohn Humbert 11-21-2004, 01:32 PM In order to remove the door trim panel, my manual says to remove the door handle (indicates removing one screw will do the trick). Removing the screw does allow the mandle & its frame to move somewhat but it is obviously still fastened somehow.. I've tried prying, applying force in all lateral directions etc. attempting to loosen whatever still holds it, hasn't worked. It's made of space-age material (plastic), so I'm afraid to apply too much brute force, lest it come loose with that dreaded "snap" we all hate (particularly as the temp. here is below freezing during the day). Thnx. JH 99TrackerConv 11-21-2004, 07:34 PM OK after you take all the screws out all you have to do is push the whole handle unit forword(towards the engine) and then it will pop out. and you can gently turn it sideways to fit it through the hole. Phu 11-22-2004, 04:23 AM OK after you take all the screws out all you have to do is push the whole handle unit forword(towards the engine) and then it will pop out. and you can gently turn it sideways to fit it through the hole. bah! turn is sideways? just pop off the clip connecting to the latch linkage. haha... 99TrackerConv 11-22-2004, 10:12 AM Hey I never thought about that. :rolleyes: That would work too. John Humbert 11-22-2004, 10:24 AM Many Thanks. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
