water pumpfreakonaleash1187 11-17-2004, 11:17 PM welp, i parked at work and came back out about 30 minutes later and there was a puddle of coolant coming from my car. after work, i checked for leaks and the water pump is leaking. so that is what i will be doing this weekend. -Jared Broke_as_**** 11-17-2004, 11:21 PM Whats up with all the beater Zs around here? :D You know what you really need to do? Twin Turbo 572CI engine swap, takes like 5 minutes more than a water pump change. Then you need to buy an F1 car. Zgringo 11-18-2004, 05:06 PM Whats up with all the beater Zs around here? :D You know what you really need to do? Twin Turbo 572CI engine swap, takes like 5 minutes more than a water pump change. Then you need to buy an F1 car. Rather than doing the swap sell me the car cheap and then buy a TT and a F1, then I'll have a N/A to play with. :grinyes: freakonaleash1187 11-21-2004, 01:14 AM looked harder today for a leak, and it is just the hose above the thermostat that has a crack in it. replaced that for $7 and my car is back on the road!!! -Jared ZedEx 11-21-2004, 10:41 PM Yea those things get dry rotted after a while or so... Luckily they're pretty cheap, $5 for a pair off courtesy. Glad it was nothing big... Your Zeds been raping you a lot lately. -Wes vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
