coolant loss
Google
Web AF
dima4855
11-17-2004, 12:25 PM
91 Montero, 3.0, Automatic, 118000 miles.
Experiencing loss of coolant through resevoir overflow tube, only during highway driving (is fine at idle).
Things I have done:
Idle test for 1 hour with A/C on, no overheating or coolant loss.
Changed thermostat, radiator cap.
Backflushed cooling system.
No visible leaks on water pump, hoses or radiator.
Tested radiator by warming-up vehicle and feeling around the radiator to make sure that it was evenly hot. It was not until we revved-up the engine to 3000 rpms.
Has anyone else had this problem or know what could be causing it?
Thanks!
dima4855
11-18-2004, 02:39 AM
Anybody out there??
usacanadiangirl
11-26-2004, 01:31 AM
I have a 95 montero LS and have just recently noticed that I'm losing coolant. I don't know how or why, just that it's disappearing. My montero has always had a problem w/ burning the oil and using the oil but that's about it. Now, I noticed this problem w/ the coolant. I am also smelling some kind of exhaust or something - don't know if it's related or not.
So I am no help to you b/c I don't know what's going on - but just wanted to let you know that I'm having a similar problem.
Have you had any insight as to what's going on since writing?
dima4855
11-26-2004, 02:41 AM
It has something to do with the pressure being excessive in the coolant system, or it could be a bad radiator, thermostat stuck closed. Something is creating the pressure. One mechanic seems to think that I have a bad head gasket and exhaust gases are going in the coolant system. I find that very hard to believe.
usacanadiangirl
11-26-2004, 07:55 PM
good luck figuring out the prob - hope you get it fixed - if you do, maybe you'd post a quick reply as to what the prob was. I'm looking to sell mine now so I'll just let the buyer know what's going on -
Google
Web AF
