93 Chevy Putters at gochevyguy93 11-15-2004, 07:42 PM Hello there. I've recently bought a 1993 Chevy Cavalier 4 Door, 4 Cyl, only 131k Km's, for $1800 Canadian. I took it for a test drive at the dealers and inspected it very throughly. After bringing it home, I noticed that it starts to putter when I step on the gas after being at a stop. When I'm at a red light, and the light turns green, I press on the gas, and it feels like maybe the tires are spinning/tranny maybe skipping. Does anyone know what this problem might be? Is there a fix? Also, my ABS light is always on. I don't kno if its that important, seeing as my brakes work fine. So it might just be a sensor. Thanks -Tim dwalmop 11-15-2004, 11:35 PM check your tranny fluid first! ttweakk27 11-16-2004, 03:51 PM Sounds like the tranny is slipping chevyguy93 11-16-2004, 04:33 PM thanks for the replies. the tranny fluid is full and brand new. and i found out, that it only happens after i've been driving for a while. ttweakk27 11-16-2004, 04:59 PM Is the tranny fluid over full after driving and at operating temps with the engine still running? Fireplug 11-16-2004, 06:10 PM Sounds like a engine miss under load check the wires and coil packs with a spary mist of water and look for any sparking and replace anything that does. Need abs code before we can help you on that 1 chevyguy93 11-16-2004, 08:19 PM Is the tranny fluid over full after driving and at operating temps with the engine still running? Thanks, i'll try that out. As for the ABS code, all I got from the reader was 12, and 66. i forget what they mean, but something about not being able to access the computer.?? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
