b16 swapswaptcrx 11-15-2004, 10:44 AM anybody know a good b16/crx swap diagram?? please help!!!!!! Thanks civickiller 11-15-2004, 02:39 PM www.google.com and search. so much posts on this already swaptcrx 11-16-2004, 12:17 PM if there is so many posts on this why don't any come up on a forum search? all i see is people telling about their swap. superbluecivicsi 11-16-2004, 10:55 PM there is alot of info, i have cd i found in my lil bros room with 420 pages totally devoted to that. some are useless info though. civickiller 11-16-2004, 11:05 PM if you cant find any then search my name and it will give you a few posts as i have swapped a b18a into my 91 hatch and have helped alot of people in the past and have explained it about 1 million times eckoman_pdx 11-26-2004, 09:31 PM if you cant find any then search my name and it will give you a few posts as i have swapped a b18a into my 91 hatch and have helped alot of people in the past and have explained it about 1 million times Just thought I'd point out he was swappin a B16A into his CRX, not a B18A.:) Swaptcrx, you want a "swap diagram." What exactly do you mean by swap diagram? CivicSpoon 11-26-2004, 10:55 PM Ok I spent 20 minutes SEARCHING, and came up with these: http://b16a.honda-perf.org/prelim.html http://www.geocities.com/droppedcrxsi/step-by-step.htm http://tjshondas.20m.com/b16ainstall.html http://www.hasport.com/Tech/Installs/Swap%20Outlines/88-91%20Civic%20to%20Non%20OBDb%20B.htm http://www.geocities.com/teampimports/b16a.html http://www.ff-squad.com/tech/wiring/wiring.88-91.jpg And like Eckoman said, you need to be more specific on what exactly you're looking for if you want help. Help us help you. A little trick to searching is searching separetly in each forum (technical, 4th gen, JDM motor, etc). Otherwise if there are a ton of threads when you just search the Honda/Acura forum as a whole, there are too many hit that will come up that it doesn't show any threads at all. I've ran into that problem many times. civickiller 11-28-2004, 04:56 PM so what if i did a b18a, b16a is the same thing, only thing is wiring for vtec, install is the same vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
