Removing bed for fuel pump change 97 Sierra
djlacavera
11-12-2004, 10:34 AM
Hi does any one have an exact procedure for removing the bed on a 97 Sierra, for purposes of changing fuel pump?
Anything hidden I should know?
How many bolts, and there location?
Wiring connector locations?
The more details the better!
Also any advise on where to get a good but economical pump for this vehicle, would be appreciated!!!
Thanks much, Nick
57ringo
11-30-2004, 02:17 PM
Make sure you get all the bed bolts, wiring to the rear lights, fuel inlet hose and ground strap off. I built a tool that it adjustable and fits under the bed lip in the middle and then picked it up with my lift. It worked very good. I used to own a NAPA store and used a couple of their pumps.......go to GM and buy one. The NAPA pumps are noisy and didn't last near as long.
MadMac56
12-01-2004, 05:46 AM
Easier just to drop the tank, change the pump, and put the tank back in...
just my :2cents:
arctic_front
08-12-2005, 08:54 PM
I've seen GM in-tank fuel pumps fail after replacement within a week....and a total of three in a month on one truck. I suggest putting in a small hatch above the pump through the bed. i suspect you'll thank me later because those pumps are really cheesy units that look like junk. a decent-looking job can be done using a piece out of another bed, scrounged from the scrap-yard. cut that piece an inch or so bigger than the hole you cut, add a small hinge and voila'
