Strange problem w/93 Jimmy 4x4
the fuel
11-12-2004, 07:23 AM
Hello everyone, good morning. Been browsing your forum for a bit now, this is my fisrt post.
I have a '93 Jimmy 4.3L Vortec (my winter car) recently purchased 2 mos. ago. I've noticed when i fill my tank with 87 (cheap gas) my car runs rough, like it wants to stall. However when i get to half a tank, it smooths out, no hesitation, idles fine. I've already given it a basic tune up (except i couldn't remove the distributor rotor though, it seemed to be stuck) and replaced the water pump and hoses, due to leak. Does anyone have any suggestions as to what my issue could be with the hesitation?? Is it just that it doesn't like cheap gas, or do i have a fuel line/pump issue??
And no, it doesn't smell like gas in the cabin, or rotten eggs, nor does it ommit any black smoke when accelarating. Thanks for your time.
troubles789
11-13-2004, 11:41 AM
Pull that rotor button with a channel lock pliers. They get a light rust film under them and fit tight. Sometimes you have to crush part of the old rotor button to get it off. Just make sure you get all the pieces out.
the fuel
11-15-2004, 06:36 AM
Thanks troubles789
BlazerLT
11-16-2004, 12:19 AM
See if there are any screws holding the rotor down.
Other than that, you need to replace the fuel filter and check inside the upper plenum for the injector leaking.
rlith
11-16-2004, 07:02 AM
There are no screws holding the rotor down on a 93 dist.
the fuel
11-16-2004, 07:13 AM
Thank you both for your feed back, i'll take it apart again this week and see how it goes.
troubles789
11-16-2004, 07:45 AM
Trust me I own a 93 jimmy too. No screws in that rotor button.
rlith
11-16-2004, 07:47 AM
95 (with side post mount) and up use a scre down rotor
the fuel
11-16-2004, 07:49 AM
this is my winter car, so i'm not very familiar with it, the guy who owned it was a mechanic himself, and he tweaked up the engine amongst other things. so everything is trial and error at this point. I guzzles gas big time, do yours do as well??
rlith
11-16-2004, 07:54 AM
I get about 20 local and 23 hwy
the fuel
11-16-2004, 08:25 AM
i'm getting less right, could be do to the fact this guy put in a K&N filter system and the casing to the air filter isn't shutting tight
BlazerLT
11-16-2004, 01:47 PM
I am close to that, 19mpg city / 24mpg highway now.
the fuel
11-16-2004, 01:56 PM
What grade fuel do you fill up on??
BlazerLT
11-16-2004, 03:25 PM
87, no point putting anything higher into a 4.3L.
Waste of money. Our engines are tuned for 87.
the fuel
11-16-2004, 03:26 PM
Really, good to know then.
