my integra is leaking gas into the motor oil help anyone??
Google
Web AF
acurky
11-10-2004, 09:47 PM
my car is leaking gas to the motor and i smell the gas in the oil can anyone help? the shop mechanics dont know why i change the fuel injector and the gas regulator but nothing im runing out of ideas maybe the pisyons or valves but i did a compresion check it was fine. or the cumputer??
integralover
11-11-2004, 02:41 AM
ok, lets start here. first off, please for the love of the rest of us that have to read your post, PLEASE SPEAK PROPER ENGLISH. i'm not really sure what you are really trying to say.
now, there should be no reason at all that you have gas in the oil. now the oil will smell alittle bit like gas, but not much at all.
so what i'm getting is that you have changed your fuel injector's and the fuel pressure regulator?
did you get bigger injector's? and did you get an aftermarket fuel pressure regulator? did you do these yourself? and how is your car running? does it idle worse or what?
now it sounds to me that you are running too rich. which means too much fuel not enough air. when you add bigger injectors and change the pressure regulator and NOT change the intake manifold, throttle body, and the intake, or add a turbo or supercharger, the air/fuel ratio is wrong now. you might also not be buring all of your gas. check your spark plugs. are they worn or do they smell of gas? if so replace them and the wires.
Technical_Automan
11-11-2004, 12:25 PM
Well here's what it probably is...spark plugs...if you miss a spark, all that fuel that the injector shoots doesn't ignite and drains into your oil...making the oil smell like gas...this usually happens if there is no spark and you continuously try starting the car without it firing...but if you've been missing sparks for a while, then enough gas would eventually drain into the oil so that it would be noticeable. Change the oil and spark plugs, shouldn't need wires too, unless they are the reason you're missing spark, and see if the oil smells like gas after running it for a while.
whtteg
11-11-2004, 05:32 PM
I would do a leak down test and test the igntion.
Google
Web AF
