Gotta Question, someone Please answer
vbeurotuner204
11-09-2004, 02:11 PM
I've got a quite a bit of conflicting info. Is my 1987 325is a 2.5L motor, or a 2.7L motor?
Celsdogg
11-10-2004, 06:59 AM
your e30 has the BMW M20B25 motor, thus you have a 2.5 liter engine.
the M20B27 motor is a 2.7 liter unit that was only used for the eta bimmers, i.e. efficiency motors. this model was presented as the 325e in the E30 lineup.
Celsdogg
11-10-2004, 07:00 AM
i forgot
the 2.7 unit was also in the plain 325
these are often called super eta's and came out later in the E30 life cycle
vbeurotuner204
11-10-2004, 10:03 AM
Ok, So What size cylinder head, will fit, work best, or work at all?
dolphinRx
12-25-2004, 04:53 PM
The answer to your second question is the exact same replacement. Use ths cyclinder head number on the side of the head. That particular head just clears the pistons when at TDC. When the head is shaved there is not much extra clearance. Strongly suggest against any mixes. When you buy a replacement USE THE SAME NUMBERS as the OEM. Thanks
