No Signal Lights
Google
Web AF
cold_azice
11-08-2004, 01:20 PM
I am having serious singal problems on my 92 Beretta. I've changed the flasher twice, but still no signal. I've checked the switch, and it sends a voltage reading to the flasher. Also I know the swictch works because when I apply the breaks and turn the signal on, the break light for that side dims. It's not the fuse because the signal lights and reverse lights run off the same fuse. My reverse lights work fine. In fact everything else works fine. Are there any relays that I should be looking at? Any help will be greatly appreciated. Thanks.
andy2005
01-21-2005, 09:18 PM
This is more of a guess than anything, but is it possible that a bulb is out somewhere.
jbmx4life
01-30-2005, 12:32 PM
I have the same prob with my 89 GT. The only way that I can get the signals to go is to hold the signal lever back toward the steering wheel, like turning the brights on, while it is up or down for the signal. I have heard that over time the contacts stop making contact and if you pull it apart, you may be able to get it to work again.
Google
Web AF
