99 astro
1986Z28
11-06-2004, 12:59 AM
my mom has a 99 astro and whenever she turns it makes a clunking sound, i know a clunking sound can describe pretty much anyting we have taken it to a mechanic and he could not find any thing, does anyone know what it could be
CD Smalley
11-06-2004, 06:05 AM
A clunking sound from where in the van? Front, rear, left right???
1986Z28
11-06-2004, 12:16 PM
its coming from the front right(passenger)
CD Smalley
11-06-2004, 01:45 PM
AWD or 2wd?
Any shake to the steering wheel wheel driving or braking?
I'd guess a loose front wheel bearing or perhaps a loose ball joint. Could even be a binding of the control arm bushing.
1986Z28
11-07-2004, 01:13 AM
thats what i thought, i regreased the front wheelbearings when i did the breaks and they where fine so it must be something else.by the way its 2wd
CD Smalley
11-07-2004, 08:10 AM
I'd take the wheels off again and just make usre that you have the right side tight enough. I did my truck once years ago and that I had everything fine. Then I noticed a grinding noise coing from the RF in left hand turns. Guess what? When I took that side apart again, I found that I had barely tightened the castle nut before I put the cotter pin in place.... If the noise started after the brake job, I'd revisit things there first. Just make sure everything is tight enough.
1986Z28
11-07-2004, 11:37 AM
thanx for all your help, i took the wheel off and thats what was wrong, i had just worked loose and allowed it to move just enough to make the clunking sound
CD Smalley
11-07-2004, 03:05 PM
I thought that sounded familiar...:iceslolan
We've all done stuff like that before. When I was in High School I changed the oil in my car once, had it up on ramps and drained it into the only thing I could find, a 5-gallon bucket. Installed new filter, put the drain plug back in place, filled it up with oil. Then I started the car up and drove it back down off the ramps..... Yeah, I forgot the 5-gallon bucket was still under the car..... Now that's a BIG mess!!! Boy did I feel like a :loser:
1986Z28
11-08-2004, 01:02 PM
yeah well you should have seen my mom freak out when she thought i ruined her van!
lportersr
05-20-2005, 02:32 PM
I had a similar problem after I had my brakes and rotors replaced at a shop. I took the van back and complained. When we put it on a lift everything was tight except I could move the caliper slightly back and forth. Turned out I needed a bushing kit which includes bushings and pins for the brake calipers. It was making a lot of noise and driving me crazy.
