Code 42 For 96 GC Limtied V8shintan17 11-04-2004, 11:00 PM I got a code 42 for my 96 GC Limited V8. I surfed on the web and found out it's a "Automatic Shutdow Relay"=Check relay and circuit"? Does anyone know what does it mean and what could be possibly wrong with the truck? Any helps will be appreciated! Cam7 11-05-2004, 05:35 AM The ADS Relay is located in the power distribution center. The PCM will set a code if it dosent see 12 volts when relay should be activated it will set acode. Check for corrosion on relay. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
