1992 Regal Brake warning light.cleek5 11-01-2004, 03:18 PM The brakes appear to work fine, however, the brake warning light and abs light are on. sierrap615 11-01-2004, 11:51 PM first check brake fluid level, if it is good you will need to pull the ABS codes to find the problem. eric trepid 11-23-2004, 02:42 PM I had a 94 Buick Regal Custom with a similar problem. After about a month or 2 after replacing the Disk pads my Brake/ABS light would come on. Plenty of fluid and plenty of brake left over. I then would replace the brakes again. 2 months later the light would come on. The amazing thing was that I found the culprit, and you would not believe what it was........the alternator. Apparently some how the electrical system wasn't getting enough power to the brake sensors. I have had the problem again since replacing the alternator. Hope this helps somebody! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
