rear window switch
Google
Web AF
ksm1213
11-01-2004, 11:15 AM
Hi,
my 94 passat rear windows cannot be opened by door switches for ages , recently even the dash mount switch failed too. i could hear "dak dak " noise but no movements.
would anyone know where i can obtain a new dash-mounted rear left+right elect window switch? ( one switch with 2 buttons for rear left and right)
many thanks
mac
boschmann
11-01-2004, 03:21 PM
If you hear the noise at the windows it's most likely a problem inside the door, motor or regulator.
ksm1213
11-02-2004, 10:00 AM
Hi ,
how should i start dismantling the door ?
i also see no light on door switch , but i fi sawp the switches with front door , it works fine.
please ive me some procedures, thanks
boschmann
11-03-2004, 07:26 PM
Le tme get this straight, it works fine with one switch but the motor makes noise without moving the window with the other switch?
ksm1213
11-04-2004, 09:04 AM
no, the suspected switch works for front window switch but not for rear .
i don't hear motor noise but just click-click sound , window will not move at all.
cheers
boschmann
11-04-2004, 06:25 PM
So no switch will make the rear window move & the noise is back at the motor. Then you have to go in & find the problem. Non-specific instructions: There should be some screws at the handle (possibly hidden) & possibly around the perimeter. The panel is held on to the door by clips at the sides & bottom, pop the panel outward then lift the top up over the window channel lip.
ksm1213
11-05-2004, 08:15 AM
Hi,
i opened the panel and saw socket and wires , what should look for , where is the motor or circuit that controls the window?
thanks
boschmann
11-05-2004, 04:17 PM
Plug it up & try it, find what's making the noise. That should piont you in the right direction.
Google
Web AF
