2003 SE Rockford AMP mod?goatnanny 10-31-2004, 01:38 AM First off iam keeping the 6 cd disk changer factory HU and order some Rockford Components Speakers for the front doors and tweeter pillars ... going to rewire the new speaker with 16 AWG speaker wires i want to overide the factory inputs for factory amp for the Front speakers and them run thru another amp (an 100watt 2 channel amp) i will install my self for the front speakers and then re wire the the rear speaker inputs from the HU into the amp then rewire the outputs to work in 2 channels instead of the factory 4 ... and by dropping to 4ohms i figure the ampage be about 150-200 watts instead of the 300 watt 2ohms on the factory amp output ... thus giving me 75-100 watts for rear speakers output and about 50 watts from the 2channel 100 watt lil amp i will install in the under the passenger front set IS it possible to make this work? goatnanny 11-04-2004, 03:25 PM Rockford 6-1/2" 2-Way 120W Component Car Speakers with Polypropylene Cones Model: P162S http://www.bestbuy.com/site/olspage.jsp?id=1069302293654&skuId=6252663&productCategoryId=cat03076&type=product Well the speakers i Order came in and i must .. i was a bit happy so i decide to go ahead and test them out in my X after taking apart the middle dash area and radio to look at the wiring set up and tracing wires to and from the amp i noticed the colors were alot different ... after taking off the passenger door panel with the old Claron speaker exposed i decide to go ahead and replace it with one of the new compenent that just came in ... To my surprise the factory speaker was glued and made into the speaker mount ... and the only way i could add the new speaker using the factory mount was to rip up and out the old factory speaker cone, magnent and all and modify the mount for the new speaker to fit into ... feel kinda bad destroy the old speaker but thats the price you pay to have thing work the way you want them too after about 3 hours of modify with nothing more than a screwdriver and sheers i was able to get the new speaker into the mount and into the door for a test fit and sound check... talk about a pain in the @ss ... I hate to see what i would have to go thru to install the new Tweeter on the Pillar .. no to mention how do i get that pillar cover off? after installing just one speaker using the factory and listening to the sound from it i realized the 6'5 inch seem to lacked some bass ... so i disable one of the dual tweeters from the included crossover ... then finally ended disabled both of them from the crossover just leaving the 6'5 inch attached to the crossover ... to my dismay i have consider just wiring the crossover from within the cab under the dash instead of the door .. i figured doing so with inable me to actually fine tweak the sound once all the panel are back in and on the X ... now i think what a pain that will be rewiring the whole front speakers from the factory amp to the doors thru that boot just to get a little better sound qaulity ... I take it everyone who had to do this to the X has went thru the same thing ... It seems like a lot of more involved than I have expected .... And i still haven't finished the front passenger side yet .. thank god I'm off work till Saturday Any ideas or short cuts on how i can speed this process up beside hiring a extra hand USMC XTERRA 11-04-2005, 04:17 PM I am about to do the same job, so I also need some advice. Post back any other tips. Good to know about the glued in speakers. Any clips break when trying to get at them? I'm doing mine next Thursday, I bought most the parts today. Mike C USMC XTERRA 11-04-2005, 04:19 PM I just realize you have a 2003 Mine is a 2005, The fact shows screws for speakers, they may have heard people complain about the glue huh. MC vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
