96 Regal fuel pump relaysEVERETT HOOVER 10-30-2004, 09:27 PM Some one please tell me where the fuel pump relays are located on the 96 Regal 3.1. Relays are on each fender and beneath the glove box. Specifically which are the fuel. THANKS. ----- EVERETT HOOVER JoeyBoy 11-04-2004, 11:53 AM I have a 91 Regal and mine is on the drivers side fender well under the hood. It has a lid on it that says fuel relay. It is not around any other fuses, it has it's own box. Hope this helps. DBSTTN 01-06-2005, 08:30 AM could this relay stop the guage from working completely JoeyBoy 01-06-2005, 08:36 AM If your gas gauge is not working, it is either not ground good inside the tank, the float may be stuck (which is not real common), or there is a small box about 1 inch by 1 inch behind the instrument cluster with 3 to 4 wires, change this. You can get one at a U Pull It junk yard for a couple bucks. DBSTTN 01-06-2005, 01:17 PM what does this little box do?? I think 95 and 96 are compatible, there just happens to be one near here JoeyBoy 01-06-2005, 03:40 PM on mine, it makes the gas gauge work, sometimes mine would work and other times, not. Changed this part and it works now DBSTTN 01-06-2005, 03:43 PM i WAS TOLD THAT A 95 IS THE ONLT YEAR OF THIS TYPE,,lORD i HOPE NOT ,I HAVE HAD THE INSTERMENT POD OUT FOR LIGHT REPLACEMENT AND DOON'T RMEMBER SEEING THIS BOX JoeyBoy 01-06-2005, 03:45 PM not real sure, but if it is then your problem is in the tank which is much worse. DBSTTN 01-06-2005, 04:46 PM I know $350 or more worse.. I am going to check a few more things tonight,,,,,let you know tomorrow vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
