Please helpxSICKBOYx 10-29-2004, 12:06 AM any info on brakes for a 92 accord EX...this is my little sisters cars and i've been messing with it for the last couple days and i'm lost...She had the master cylinder replaced less than a month ago..car leaks like a fuckin civ...ABS light is on brakes work but ABS is inop. I was looking at the accumulator under the rear resovoir and it is dripping from the bottom of that accumulator..the one withthe four hex heads bolt in it when you remove the plastic tank...i don't have the tools to get the brakes line off properly to get at it...any idea on a fix or possible soulutions as i'm tired of the shops telling her it's gonna cost 1600 bux to throw a new part in....this thing has to be serviceable..thanks in advance phantastic1 11-03-2004, 12:17 AM you can try removing the resovoir....once removed...you should see a o-ring at the bottom of the resovoir. try replacing that to see if it will fix the leak...however it's never a good idea to service your abs component....that's why the mech recommended to replace it. and yea...the abs component is expensive. scubawrstlr 11-03-2004, 10:12 PM Sometimes i'm glad i don't have abs. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
