Startup stall...electrical?MLK 10-27-2004, 03:32 PM Something is going on with my '99 Grand Am GT. It starts up (with a little hesitation), then stalls. When it stalls the power to the radio is cut off and the time automatically resets to 1:00. It usually starts right back up and nothing else appears to be affected. I have had several electrical problems with this car.recently replaced the alternator but I think this had happened a few times before that....any ideas for things to check? GTP Dad 10-27-2004, 04:46 PM Check the main ground coming from the battery. The battery lead may be bad and not showing on the outside. Given the fact that the radio resets then that indicates a total loss of power and I would suspect either a bad ground, bad wire or even a bad BCM. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
