89 Accord LXI wont start
*floman*
10-26-2004, 10:57 PM
I am new to the site so I hope you can help. I have a 89 LXI and it will not start. I was going down the freeway and it just quit running. I have checked for spark at the plug and it is o.k. I have checked the fuel pump and it seems to work when I turn the key on I hear it for just a few seconds. I also checked at the fuel rail and it has fuel and pressure.
I replaced the main relay thinking that was the problem but that was not it. It will turn over and over but will not start! Help!
gitter44
10-27-2004, 11:09 AM
Check the timing belt...
*floman*
10-27-2004, 05:25 PM
Took the the oil cap off of the valve cover and valve train looks like it is moving up and down. I think the belt is o.k. Thanks!
mpumas
10-28-2004, 02:57 PM
Looks like you checked all the things I would check. Next thing might be to pull the plugs and check compression. Check the fuses that go to the fuel injection system. Could be a fuel injector power problem. When you find out and resolve the problem be sure to tell us. We all want to know.
*floman*
10-28-2004, 09:04 PM
Checked compression and it is good. I also checked all the fuses that I could find that controled anything that might be associated with a fuel or ignition problem. I think you might be right about the fuel injector power problem but I do not know what to check and where it might be. Thanks.
ciccmga
10-29-2004, 10:39 AM
The next thing I would check if I were you would be the timing itself. If the belt jumped, the timing would be off and it would not start.
