!972 Slant Six Duster, Turbo projektBadA$$Snake 10-24-2004, 09:21 AM Hey guys, I'm just a yougn buck, only 16, so I just got my permit, but I already have a car A decent 1972 Plymouth Duster. My dad started otu with that same car, but it was a 1973 340. Ok hers the problem I have two options. I could go with an engine swap, I have a donor 1975 360, modified(on a scale from 1-10 teh mods are like a 6.5) I would liek to do this seeing as to how the torque and hp would be reasonable, but I want to take the road less traveled, and do a Turbo. I don't know exactly how I would do this :banghead: , kause I am suret they don't make all teh components I need, but I was thinking along the lines of t3/t4 hybrid and possibly making the exhaust to fit. Any feedback on my plans would be greatly appreciated, thanks. I do plan on racing this car, so theres my connection to the Street racing section, heh. :grinno: CassiesMan 10-24-2004, 06:27 PM Welcome to the forums! I dont know much about older cars, but I think you should go over to the Forced Induction forums, I'm sure someone will definately be able to help you there. Its under the cars in general section BadA$$Snake 10-24-2004, 07:00 PM Thanks al ot man, I have seen you in a quite a few forums you seem like a cool man, Catch you later. CassiesMan 10-24-2004, 07:14 PM Thanks, yeah I get around a bit on here, mostly here and motorcycles, but every now and then I drop in on the Bimmer forums. BadA$$Snake 10-24-2004, 07:43 PM E46 isn't that the new M3 motor code? I like Bimmers a lot but I'm not real knowledable on them sorry, hh CassiesMan 10-24-2004, 08:00 PM E46 is the current chasis code. 1999 to appearntly 2006 will be E46s. After that I think its gonna be E90. The motor in the new ///M3 is either S54 or S52, I'm not quite sure. I'm pretty sure its S52, and the S54 is on the M Coupe. CassiesMan 10-24-2004, 08:04 PM Edit* Quick search shows that the S52 is the Euro Spec 3.2 on the M3, in the US, they use the S54. jonnyboy9012 10-24-2004, 08:27 PM I personally think you should go with the 360, but if you where able to go with a 360 forced induction that would be the shit. But if your looking for fuel economy it would have to be the 6 cylinder. chevydrummer76 10-24-2004, 08:51 PM honestly that six wont get much better mileage then the 8. jonnyboy9012 10-24-2004, 09:39 PM honestly that six wont get much better mileage then the 8. If you have a v6 it is two less cylinders that you have to feed gas/air into, now if your use to the performance of a v8 and always push the v6 alittle harder to get the same results yes the v6 will have the same or worse fuel mileage, but if you are a calm driver that is light on the gas you will have better fuel mileage with the v6. 76455Firebird 10-24-2004, 10:50 PM I'd say go for the 360, you can get some good performance number's out of those engines, quite a few performance parts for those engines. samandiar 10-25-2004, 12:31 PM Well, the slant six gets around 20mpg, 25 if you drive like a grandma. Mopar small-block V8s, however, get horrible gas mileage. My friends 318 Ram gets 10mpg and he doesnt drive fast. that said, ford straight-sixes seem to get pretty bad gas mileage. The 79 Ford granada i used to have had one, and it got 14 mpg!! of course, it had 185k miles on it. So if you want a six, get a mopar one, but it seems you already have, so good luck! (go with the 360 if you want performance, i dont think a slant six can handle too much boost) BrakeTorque 10-25-2004, 05:25 PM hey same im 17 but have had alot of build ups and fixing cars since i was 14 but dude id say get the 360 tough motors and they have some mean power if bored out. Get a set of headers and go to your local machine shop and get some pipe and bend them into some nice 3" duals. Maybe get a cut-out for the exhaust. :) that should start you off. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
