gsr turbo
Google
Web AF
merce
10-24-2004, 01:27 AM
I want to run at least 10 psi on my gsr. What would I need to do to run this safely and what would be the cheapest way to do it.
YellowITR479
10-24-2004, 07:25 PM
Either build the bottom end which is not cheap at all...or put a thicker headgasket on the car but make sure you have enough fuel
civickiller
10-24-2004, 08:11 PM
dont say you want a psi, tell us how much hp you want. different turbos and make different hp at the same psi level
merce
10-24-2004, 08:39 PM
I'm getting a greddy turbo kit, I dont know how much hp i want, however I do know how much boost, 10 psi.Whatever hp 10psi makes I'm cool with.
civickiller
10-24-2004, 09:06 PM
so i see yoru not in it for the power, your in it just to say that you run 10psi. :disappoin
well with a stock gsr, push it to either 300whp or 10psi whichever comes first but with a greddy kit i doubt youd hit 300whp at 10psi probably wouldnt hit that till after 10psi. but if you do some how manage to exceed 300whp at 10psi, i would recommend a small build up of rods and pistons lowering hte cr to something under 10:1 like 9.5 or 9
oh the reason i say 300whp because a stock block can handle 300whp reliably so if you can hit 10psi before you get to 300whp then your ok with a stock block but if you hit 300whp befor e10psi then you gotta build your block alittle.
merce
10-24-2004, 11:07 PM
If I was to do a small build up where can I get it done at. I live in south Dakota and there aren't any performance shops in my area. They have some machine shops but I'm not sure if they do the work.
o0Quicksilver0o
11-02-2004, 11:02 PM
gsr's have pretty high compression. so if you turbo it your looking at alot of pressure on the internals at full compression stroke. so i would work on lowering the compression. a thicker head gasket and low compression pistons can take your compression into the high 8's. cars that come turbo stock have a compresion in the mid 8's so i would consider that pretty reliable i would say with those to mods 10psi would be fucking easy i would say you could push it to 12 if you got the balls and the fuel management to back it up.
civickiller
11-03-2004, 03:29 AM
jeff@IB has his stock gsr block with a thicker hg pushing 350whp @ 11psi but idk how low his cr is
o0Quicksilver0o
11-03-2004, 07:53 PM
i am guessing sense they start with a 10.5:1 he would probly be at like 10:1 maybe a little lower but dunno for sure really. still high compared to the D :biggrin:
Google
Web AF
