Fan motor only works on high still after resistor block changeMojoman 10-23-2004, 07:19 PM I replaced the resistor block on a Sebring convertible and the fan still only works on high, I heard that it could possibly be a manufacture defect in the blower motor. Help! PashaDNN 10-24-2004, 01:48 PM Mojoman 10-24-2004, 09:33 PM The one i changed actually looks different than the one you show, but it did not work either. Maybe the new part is bad also. I did a continuity test on the switch, it was OK. From the schematic I have i do not see any thing else in between the switch and the resistor block. hundahunta 10-27-2004, 12:07 AM you need to remove the connector to the resistor block, back probe each while one at a time while turning the ac control knob..it should have continuity to ground vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
