94 APV - resetting the computervalgoak 10-21-2004, 11:49 PM My 94 APV van's air conditioner quit working - I found the compressor wasn't running - but that if I reset the van's computer - that it would work for a good 20 mins or so - then stop (the compressor). I am thinking it is the relay? Has anyone had this issue & might know what it is ? I hate to take it to a shop - they always seem to have me spend $800 to $1,000 each trip. The reason I reset the computer on it was because I replaced the battery and found the only way for it to stay running to reset it - then it was fine. Thanks !! dwalmop 10-22-2004, 12:26 AM In my experiences, when the compressor quits running, it's because there is little or no refrigerant left in the system. Try checking that out, you may have a leak somewhere. If the relay was bad, I don't think it would run for the 20 min. or so you said it runs after you reset the computer valgoak 10-22-2004, 10:08 PM I did check the coolant & it was great - in fact I spent all the money for the gauge to check it / the adapter to fill it and the coolant - only to find out after I kept checking it and it was fine for my nephew to say - well, the compressor is not running - So, I thought maybe the relay thinking it might be it because a reset of the computer would reset the relay...? I was hoping someone could confirm this before I spent the money for it. Thanks! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
