is switching to elec fans the way to go?
johnnyboy5
10-20-2004, 08:58 PM
is switching my v-belt fan to elec fans really a good choice. I mean, i know it saves on power, but my friend says that the 240 came with a v- belt fan so i should keep it that wy, other wise elec fans are not efficient in cooling the radiator. He also said that it complicates things. Whats ur opinions?
lucki17
10-20-2004, 11:52 PM
id say go for it, i might just to free up some space, i dont think it frees up that much hp, but hey might as wall try it.
SR20DETpower
10-21-2004, 12:39 PM
its great, you can also run the fans when the engine is off, like at a track or such to cool it down...
they work good, you just have to get a proper shroud for it.. also clutch style fans sound like SHIT... it is a good mod to do
I would wire it up to a switch in the cabin so you can turn it off and on yourself, as well as have a light for it that lights up when the fans are getting power.... just so u don't start it up one day and drive to work with the fans off lol
nissanfanatic
10-21-2004, 01:14 PM
I've actually heard of people just using the stock electric fan and having good results. I am debating on whether or not to just use it without the clutch fan.
SR20DETpower
10-21-2004, 01:50 PM
it really matters where you live... if you live in a cooler rural area cooling is not a problem...
if your like me and live in hot ass South Florida with a shitload of traffic you can never have too good of a cooling system
Partizan
10-21-2004, 04:24 PM
SR is right if you face heavy traffic it can be a bitch. Next time on a hot day in traffic just watch the needle rise, let alone if you try using the AC. I would go for it and the switch idea sounds good but makes another thing that can go wrong by just forgetting to switch it on or off.
GT500916
10-21-2004, 04:49 PM
im going to switch myself, because the clutch fan does sound like crap!.. so what i did is went to a junk yard and pulled 2 fans out for $50, one out of a sentra i think and another similar one out of another nissan, forgot what it was. I will connect one as the AC fan and the other one as the radiator fan.
Is there a way to make the radiator fan turn on and off by itself when the engine gets hotter? or will that require more work? the wiring would be a paint, but its worth it once its done.
240sxAddict
10-21-2004, 10:35 PM
will it be better 2 go for aftermarket fans or just junkjard??
kane2g
10-21-2004, 10:51 PM
summit sells a thermostat that will do just that @ about $25
johnnyboy5
10-22-2004, 04:54 PM
all righty then thanks a lot for the info, im gonna get paid today (hopefully) so by tomorrow i'll probably go to the junkyard and get them. Would any nissan fans do , or should i take the dimensions of my radiator or go for a specific model to take em off from? I heard nissan sentras work best. After i get the fans i'll need some help on installing em if i cant get my cousins to help me out. So i'll keep postin'. Thanks again.
GT500916
10-22-2004, 05:28 PM
to be honest with you i wasnt sure which ones fit and which dont, i got a 95 240 and im guessing the older 240s have a different size radiators, and i dont know what 240 generation you got, but i was looking at the sentras with the SR20DE engines... there are dual fans and single fans, the dual fan set up has one big and one small fan on the sentras, but the pegs on the dual fan shroud will not go sraight into the holes on the bottom of my radiator, they are to wide. So what i did i bought 2 single ones.
I was at the junk yard over here pulling fans left and right and meassuring them and trying to figure out the best way to go without coming back, so for me the dual shroud was out of the picture, so i started messing with single fans and trying to make that into a dual set up with 2 fans. I got one of a SR20DE sentra. there is a radiator fan and a AC fan, the AC fan has 4 blades and radiator one has 5 blades. There are 2 different types as well, some have little motors and some have big ones, i wanted to get the big motors, so what i did i found 2 5 blade fans from nissans with 5 blades, this way even tho they are both radiator fans i can put them next to each other and one will be set up as AC fan and another as Radiator fan.
This is all trial and error, but im still going to try and figure out on how ill be setting this up, i will have to take off my stock clutch fan and shroud and then work from that.
I will be making a diagram soon and the meassurements of the fans and the radiator and mounts and brackets ill be making, this might be helpful for others to do the same set up. In about a week or so i should be able to have something going if it doesnt rain here or anything.
as for the thermostat im gonna have to look for that at summit as well and see what i can do with that.
Bryants95240sx
10-22-2004, 07:44 PM
altima fans fit the rad. perfect the shrouding it self needs a lil triming to fit between the frame rails but they work really well. i just droped my mech. fan last week made the engine a lil more revv happy. two weeks ago went to the 1/8th mile track ran 10.5s all night long went last night ran 10.3s al night and one 10.2 and it was WARMER this week than two weeks ago so there you go. and ive had NO over heating issues and i live in alabama so...
johnnyboy5
11-19-2004, 08:49 PM
So GT500 have you completed the switching of fans yet, i went to the junkyard with my friend but we didnt have time to take em off a sentra, and there werre no altimas, but there were some old maximas with some elec fans and another 240 with the fan in front of the grill, we were there taking out some parts for his car.
johnnyboy5
11-19-2004, 08:52 PM
Oh and by the way, at what the governor speed limit for civics, there were two racing today and i dcided to join em (border of mex to sd) i caught up to them and beat em for a while, after that there was some traffic so we slowed down and then went at it again, there were pretty fast for civics, when they would pass me i would catch up but then the governor would kick in, so i cant say that i beat em or not
mynismo
11-20-2004, 08:07 AM
you will notice more power when switching to efans.
and you'll cool better if you have a good set of dual fans. i recommend getting a set of duals out of a junkyards of a maxima or altima, or similiar.
and don't bother with a fan temperature controller. just wire them to the ignition. temps are perfect on mine and i've been doing this for 4-5 months in all kinds of weather.
do it.
nissanfanatic
11-20-2004, 01:04 PM
do it.
I just got rid of mine and the only thing I have noticed is that my fan shroud isn't hitting the fan anymore and the engine bay is much quieter. The stock electric fan is working great for me and I live in Florida. The temp gauge is at the same place it was with the mechanical fan.
D-Bo
11-20-2004, 02:44 PM
are they an easy install? as in the ones from an altima or maxima?
mynismo
11-21-2004, 02:18 AM
that's because the stock temp gauge stays in the middle whether its 140F or 210F.
electrical fans aint too tough to install. the toughest part is the wiring.
TatII
11-21-2004, 03:40 AM
oh my car, the e fans are soo diesel, the car can't maintain operating temp if i leave it on. it only kicks on when the temp goes up past a certain part. this is with no thermostatic switch but on a stock harness. when i turn on the defogger, the a/c fans kick on, and while i'm driving, the temp goes down to cold!!! and stays there!!!
johnnyboy5
11-21-2004, 08:54 PM
what? :sly:
johnnyboy5
11-21-2004, 08:55 PM
Anyways...
n e one has a wiring diagram, this will benefit to not just me but a lot of people and make the work easier.
