88 cherokke 4.0 hard to startcaddy94 10-20-2004, 11:13 AM I have a 88 cherokee that sometimes will fire up then stall right away and will do this for like twenty times and then just run fine , this only happens sometimes but seems to be happening more often ,runs good when its running , did complete tune up about two months ago so dont know where to proceed next and also check fuel presurre around 31 and it maintained that pressure for a awhile but thats when I wasnt having any problems any ideas? Dale Aeppli 10-20-2004, 01:04 PM I have a 88 cherokee that sometimes will fire up then stall right away and will do this for like twenty times and then just run fine , this only happens sometimes but seems to be happening more often ,runs good when its running , did complete tune up about two months ago so dont know where to proceed next and also check fuel presurre around 31 and it maintained that pressure for a awhile but thats when I wasnt having any problems any ideas? HI, CHECK ON THE DRIVERS SIDE INNER FENDER THE IS A WHITE CERAMIC RESISTER WITH TWO WIRES, THIS IA S FUEL PUMP RESISTER TRY PUTTING A JUMPER WIRE ON THE TERMINALS IF THIS WORKS REPLACE THE RESISTER HAVE PICTURE HOLLER IF YOU NEED IT DALE email jeepman600@aol.com :nono: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
