Supercharging a type R
Google
Web AF
integra794
10-18-2004, 06:22 AM
Im about to buy the vortech supercharger for my Type R engine. But what i need to know is there a better alternative? I am looking for 1/4 times. It would be running at a 12psi high boost pulley. What would i get more out of my engine a turbo or a supercharger? Thanks.
superbluecivicsi
10-19-2004, 04:58 AM
What you need for the type R on boost is a good fuel management. ESPECIALLY@12psi...............it should be a required and neccessary component for boosting your type R.
May I be the first to warn you.
integra794
10-20-2004, 03:43 AM
The vortech comes with a proper kit that includes evrything needed including the fuel system. Is it possible to modify my internals for safety becuase i will be running at 12 psi?
eckoman_pdx
10-21-2004, 06:26 AM
12psi on a type-r on street gas will require lower compression normally, which then negates it from being a type-r...the reason it's a type-r IS the very internals you wish to modify.
pikkagtr
10-25-2004, 04:52 AM
yep
so run it around 6-9 psi and you wont have to beef up the insides too much
maybe a thicker head gasket
personally i like my R N/A
civickiller
10-25-2004, 07:25 AM
get a good ems like hondata, find a really good tuner and keep tuning and turning up the boost till it starts to detonate adn then back it off alittle. best way ot reach your max. but i also wouldnt exceed 300whp on stock internals
Google
Web AF
