2000 camry le 4 cl car would not start
damie
10-16-2004, 11:57 PM
2000 camry le 4cl got sparkes got gas got ignition but will not start
car crank an then injector fire 2 tmes then nothing even if are still cranking if you turn off and try again same thing
don24mac
10-17-2004, 08:06 AM
Need a little more information. What has changed since the last time it was running? What led up to it not working? Was it working fine one day, and not the next? Did the problem start after a fill-up of gas?
yotatechie04
10-17-2004, 11:21 AM
Check your fuel pump and filter. If your fuel filter hasn't been replaced yet, it might be a wise idea to go ahead and invest in one. But you will need to check to see if your fuel pump is putting out enough power to pump the fuel to the block, if not, then the pump needs to be replaced.
damie
10-18-2004, 09:09 AM
i was driving tha car ay the time
damie
10-18-2004, 09:12 AM
fuel pump is working great
Brian R.
10-18-2004, 11:26 AM
Did your "Check Engine" light come on before it died? If it did, get the codes from Autozone or some other parts store that will download the codes.
How do you know the fuel pump is working great? How did you check it?
damie
10-18-2004, 08:34 PM
yes i checked it and there is no codes checked it to
csaxon
10-19-2004, 04:12 PM
Probably a stripped or broken timing belt..how many miles are on it?
damie
10-20-2004, 10:22 AM
66000 miles checked the timing belt it is good
damie
11-01-2004, 10:36 AM
car is running it was the coil all of then
do not know way they burnt out
don24mac
11-01-2004, 12:49 PM
Thank you for the update. Happy to hear she's running OK again.
