Little pop sound
coolguycooz
10-13-2004, 10:09 PM
When i drive i shift in to a gear and when i let go of the clutch it makes a little pop sound i dont know it seems weird. Just wanted to know what it could be it only does it when im putting it in to gear engaging the clutch. Also when i back on a straight line i try to drive and as soon as i let go of the clutch my wheels peel out in reverse and i hear a pop then it staryts to normally accelerate.
EclipseRST
10-13-2004, 10:24 PM
go read the sticky and sign it... then i will help you!
EclipseRST
10-13-2004, 10:34 PM
ok another thing... USE PUNCTUATION! its hard to read... seems like something on your clutch is sticking or isnt adjusted right! do you have the right about of clutch fluid in there, how long has it been since you change the clutch... need more info
1stGenRocks
10-13-2004, 10:57 PM
"Also when i back on a straight line i try to drive and as soon as i let go of the clutch my wheels peel out in reverse and i hear a pop then it staryts to normally accelerate." are you saying that you dont stop to put it in 1st? because you should stop moving backwards before you put it in forwards
