Page updated on 04-24-2018
Coolant system air lock
Bravetex
10-13-2004, 05:35 AM
Looking for procedure to remove air from coolant system. I've seen it referred to on this forum as "burping" the coolant system.
Dober89
10-13-2004, 05:12 PM
I think the LT1 system has 2 bleeder screws.
LT1 Coolant Drain and Refill Procedure
http://shbox.com/1/4th_gen_tech2.html#radflush
LT1 Cooling System Operation & Testing
http://shbox.com/1/4th_gen_tech2.html#cooling
DaMoNe6969
10-13-2004, 05:40 PM
the way I do it with my supra (no bleeder valves) is jack the front end up or do it on a steep hill.. so that the rad is the highest point in the cooling system, take the rad cap off and let it run at 3000rpm's for a while
justlearning
10-13-2004, 10:54 PM
all i do when i drain my radiator is open the cap and let my engine idle till fluid rises to the top of the neck then put the cap back on and cap the reservoir wala
Dober89
10-14-2004, 04:47 PM
Letting air out of an LT1 cooling system is different from any older cooling systems.
