1994 Astro flwheel coverwarrenzevon 10-11-2004, 10:10 AM I have a 1994 astro that I swapped the trans a few years back and did not reinstall the flywheel cover/shroud, now I just failed inspection and need to find a replacement. does anyone know what model the auto trans w/ overdrive is? I dont remember. also anyone know if a cover from any other model trans should fit? LTJGWorth 10-11-2004, 06:25 PM 700-r4. Check Ebay. I actually did a swap in my van too. Luckily, they don't do inspections around here, so I left the cover off as well. That thing is hard as hell to get back on! LTJGWorth 10-12-2004, 04:30 PM Here, I did the searching for you. It's the only one I could find on eBay. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=46104&item=7926333631&rd=1&ssPageName=WDVW berniebo 10-16-2004, 03:07 AM Your tranny is a 4L60E which is the electronic version of the 700r4/4L60. 1993 GM switched all rwd passenger vehicals, 4,6 and 8 cyl to the 4L60E. The inspection covers should be the same though. Good luck!. ebu187 10-22-2004, 10:56 PM if its a tin one anyone will fit if its aluminum only 4.3/5.7 will fit, go to the local junkyard not ebay. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
