Squeaky noise coming from driver's side??Speedi 10-10-2004, 09:37 PM Well, I have had my Colorado Sport Crew Cab since March 2004, and I have to admit that it has been completely joyous... until now. Recently, I have had three issues. 1. The AC seems to make a high-pitched whistling noise as the compressor kicks on or off. 2. I have developed an extremely annoying "squeak" somewhere around the drivers door? Doesn't seem to happen ALL of the time, but MAN, when it happens, it will just about drive me out of the cab. I can't figure out where it's coming from?! If I accelerate or brake, the noise seems to subside. When I turn to the left and right, the noise also seems to subside. I have tried opening and closing the door as well as letting up/down the window (but then I can't hear it) in an attempt to make the noise go away. The squeak sounds like rubber or plastic rubbing together in an attempt to drive me insane! 3. I have managed to run over SOMETHING that stained 3-4 small spots behind my wheels, on the body, a red-tinted color. The body shop has tried everything EXCEPT buffing the paint with a machine. They ultimately recommend I just leave it as rubbing compound was not removing the stain. Any ideas? I'd love to hear some suggestions regarding these topics. Tx. - Speedi grassruts311 10-12-2004, 06:49 PM I have a z71 colorado and i had that same problem. i took it in and the chevy guy said that its not unique, and that the GM engineers are currently workin on a fix for it. I will let u know when they do. If you have any more questions e-mail me at grassruts311@hotmail.com Speedi 10-12-2004, 10:04 PM I have a z71 colorado and i had that same problem. i took it in and the chevy guy said that its not unique, and that the GM engineers are currently workin on a fix for it. I will let u know when they do. If you have any more questions e-mail me at grassruts311@hotmail.com Thanks, so this is common eh? Is there a workaround for the squeak? I can't seem to pinpoint where the noise is coming from... but it sounds like front left, either dashboard level or a little below. I, personally, do not see anything that moves in this area... so a squeak evades me, completely. I do notice that pressing the brake seems to make it subside, but I think it's coincidence. - Speedi fmhopson 10-23-2004, 12:57 AM I also have squeaky noise can't figure out what causes it. Speedi 10-23-2004, 09:49 AM I also have squeaky noise can't figure out what causes it. I have put some Lexol Rubber/Vinyl protector around the door seals and greased the hinges (I wouldn't think the latter was it, but what the heck) but that didn't help. It has since started raining and I believe that has made it go away. I haven't heard it in about 2 days. I washed the truck yesterday, and still, no squeak. It had gotten so bad that I could just pull into the garage and I could hear it when I was tapping the brakes to complete the pull-in. Annoying. I want to say it's coming from INSIDE the door? I have also noticed that when I let the drivers side window down, there is a thud.. almost as if the window is being yanked down by the motor and then something "catches". Letting the window UP does not make any sound. Any ideas on either of these topics? Tx. - Speedi chrisk19938 10-30-2004, 10:03 PM i have a squeek as well on the driver side. HOWEVER it seems to me mine is coming from the SEAT! like the mountings or something Speedi 11-01-2004, 07:20 PM i have a squeek as well on the driver side. HOWEVER it seems to me mine is coming from the SEAT! like the mountings or something I initially thought the same thing. I could rock back and forth in the seat to make it happen. Like I said, it rained and it hasn't been back? :eek7: So, you can imagine how puzzled I am. There is no way you can take your car to the dealership with a phantom noise. It has to be there ALL the time and they have to be able to instantly reproduce the issue. - Speedi nj40fan 11-15-2004, 12:59 PM Check the emergency brake cable running along the frame under the truck (coincidentally, under the driver's seat). Mine was rubbing on the frame and squeaking and I applied grease where it looked like it was hitting the frame. Squeak went away. Good luck. Speedi 11-17-2004, 09:02 PM Check the emergency brake cable running along the frame under the truck (coincidentally, under the driver's seat). Mine was rubbing on the frame and squeaking and I applied grease where it looked like it was hitting the frame. Squeak went away. Good luck. I will certainly give it a try... it's crazy because I simply can't isolate it.. it's almost an omnidirectional noise coming from the driver's side. Thanks for the suggestion. Is this one of the many cables running along the frame that's easily visible from the driver's side of the truck? Tx. - Speedi nj40fan 11-24-2004, 08:56 AM Is this one of the many cables running along the frame that's easily visible from the driver's side of the truck? Tx. - Speedi Yes. It is the one that runs along the frame on the driver's side that you can see hanging down especially when the parking brake is applied. Good luck. nj40fan snyde13 12-13-2004, 10:31 PM ive got the same squeek with mine annoying for sure ive got no clue though ill be trying everything ive read here tomorrow though thanks themomonga 03-01-2005, 02:39 PM I had the same kind of squeek coming from both my passenger and occationally my drivers side(2004 Colorado Z71 Crew, drove 3/04-2/05 17k miles). It nearly drove me to insanity!!!! I finally isolated it at the V where the door/roof support beam meets with the dash. I did a temp fix by jamming my air freshener in between the dash and the beam. Note: you may need to adjust the position a little before the sound goes completely away. I have since sold off this POS and gotten the hell away from it...nothin but problems. Moved to a proven quality truck (2001 Chev Silverado Z71 LT Ext Cab)...not it is a 2001 B4 they started getting TOO cheap on the production lines! Never been happier! ;o) osterman 03-22-2005, 09:17 PM Did anyone ever figure out what this is from? I have this exact problem. It sounds different when I speed up, slow down, or brake- and the sound often completely goes away for long periods of time randomly or when I turn. I can't pinpoint where it's coming from and often sounds like it's in the door. Did anyone try checking out their parking brake like a post suggested? If so, did it work? What did you do? Thanks! CanoeFly 10-18-2005, 11:23 AM 2. I have developed an extremely annoying "squeak" somewhere around the drivers door? Doesn't seem to happen ALL of the time, but MAN, when it happens, it will just about drive me out of the cab. I can't figure out where it's coming from?! If I accelerate or brake, the noise seems to subside. When I turn to the left and right, the noise also seems to subside. I have tried opening and closing the door as well as letting up/down the window (but then I can't hear it) in an attempt to make the noise go away. The squeak sounds like rubber or plastic rubbing together in an attempt to drive me insane! Tx. - Speedi[/QUOTE] I have a similar squeak which I agree can "drive one insane". I liken mine to a nest full of baby bird chicks. I've noticed that this intermittent noise is temperature and humidity dependent. Cool, damp conditions will bring it about while the summer heat keeps it more at bay. I've had it to my Chevy dealer once and they were sure they had it fixed due to a service bulletin about brake cable noise, but it didn't do any good. The sound itself seems to be coming from the dashboard but it's really somewhere UNDER the dash. I determined this by driving with a stethoscope in my ears and placing it at the top of the dash where I heard nothing. I can replicate the noise by driving slowly down hill in 3rd gear or higher using the engine as a brake. A rough road surface helps to generate some suspension movement and the baby birds really start to squeal. Turning the steering wheel abruptly back and forth changes the pitch dramatically as well as tapping or pumping the brakes. The dealership owner heard the noise but I doubt that it was communicated to the mechanic who actually tried to fix it. The dealer says "If we start taking the dash apart you might end up with more squeaks and rattles". In my opinion that's not a good excuse for not finding the source of my problem. I'm going to try the dealer again and insist that the mechanic goes along for the ride. I find it really embarrassing to have a passenger who says "this is a new vehicle and it squeaks like that?". In Pennsylvania we have a real good Lemon Law. A couple of more tries with the dealer and GM can have it back. Any new ideas out there as to what is the cause? I like the vehicle otherwise, especially the fuel economy with the rwd 4-cylinder. Canoefly Speedi 11-27-2005, 03:51 PM I find it really embarrassing to have a passenger who says "this is a new vehicle and it squeaks like that?". In Pennsylvania we have a real good Lemon Law. A couple of more tries with the dealer and GM can have it back. Any new ideas out there as to what is the cause? I like the vehicle otherwise, especially the fuel economy with the rwd 4-cylinder. Canoefly I have had the squeak fixed, once I was able to take it over to the shop with it actually happening. The guys at the dealership re-routed the brake cable and all is well... has not happened once since. :biggrin: So, bravo to who said it was the brake cable... the one that runs along the drivers side on the frame. - Speedi 97cavalier 11-27-2005, 09:24 PM I have had the squeak fixed, once I was able to take it over to the shop with it actually happening. The guys at the dealership re-routed the brake cable and all is well... has not happened once since. :biggrin: So, bravo to who said it was the brake cable... the one that runs along the drivers side on the frame. - Speedi I had same issue, but i here some are the brake line and if that is not it you have the same problem as me. Mine had the noise and i had aftermarket nerf bars put on and it was thoes. Where they mount the bolts were not long enuf and it was to tight and was runnbing against the frame so the nerf bar manufactuor sent me new bolts and no more squeek. drjslj 12-17-2005, 04:19 PM I can vouch about the emergency brake cable. We had the same thing happening on our 2005 so I took it to the dealership and of course it would not do it but I was persistent so they had a mechanic to get in the bed of the truck and one under the truck and when he bounced up and down they found that a bracket that held the emergency cable was hitting against something so they moved it and we haven't had a problem since. RahX 03-27-2006, 09:27 AM Mine has the squeak and i havent tried the emergency brake cable yet. I noticed the drivers headlight makes the same noise when i wiggle it around so im working on locating where that squeak is. mine isnt bad i only hear it when the radio isnt on :o Murphster05 05-13-2006, 07:07 PM ok, mine is doing the same thing, I am ready to SHOOT MYSELF IN THE HEAD. It is the most terrible noise IN THE WORLD. I would rather have the annoying, high pitched, stereo whine than this crap! I am going to take a look at the E brake cable, (btw this is in a 2001 silverado so chances are that isn't it? I don't know...) but it is terrible, if anyone else can give some info on the silverado that would be great, but until then to e brake cables and e brakes I go. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
