92 buick lesabre custom is vibrating at 1500 to 2500 rpms
92lesabredriver
10-07-2004, 01:46 PM
hello all buick lovers... just bought a 92 buick lesabre custom tan/gold paint with tan leather nice car but.... it is idling rough and when i accelerate moderately not fast not slow just reg. when i hit about 1500 rpms it vibrates real bad and only stops if i punch it or let off the accelerator completely. i dont understand it no one ive talked to has ever heard of it. its not the axles or the drive train i dont believe. i think it has to be something with the fuel system or i dont know any suggestions would be much apreciated. and no the service engine soon light only comes on once in a blue moon for like 5-10 secs then goes out. so the mech. told me he cant get a code cause it doesnt hold it when the light goes out so im lost help me find my way.... JB
Lesabrelover
10-07-2004, 05:27 PM
Replace the spark plugs and wires and the fuel filter.
92lesabredriver
10-07-2004, 05:33 PM
Did that as soon as i got it, but nothin changed i also did a transmission flush a oil change and put some fuel injector cleaner in also no difference
92lesabredriver
10-07-2004, 05:37 PM
someone told me it could be the motor mounts but how could that be it only does it at that certain rpm?? im lost as hell its not a normal vibration either its quite severe and when im sittin in traffic it idles real rough and low under 1000 rpm about 500 or 600
yogi_123rd
10-07-2004, 07:01 PM
Have a mechanic checkout the harmonic balancer. It's a heavy cast wheel that a pulley mounts to at the front end of your crankshaft. It's purpose is to dampen vibrations.
buickmastermind
10-09-2004, 07:46 PM
WRONG WRONG WRONG WRONG. CHECK THE IGNITION COILS. THAT IS THE PROBLEM. pull the wires of the posts, and if you see a weak, uneven spark, or no spark at all, Problem: Found.
girlmechanic
10-29-2004, 08:41 PM
I am having the same problem, I changed the ignition module, cause the check engine light came on, but i went to autoone when it was on, and that was the code, the problem is still there. I checked the wires and plugs too. It shakes so bad when you accelerate, unless you gun it or let off the gas. It is a fuel problem for sure, when you are at idle you can hear the missing from the exhaust, and very little white smoke. just cant figure this one out, I just got this car and dont know whats been replaced. It was fine till all the sudden I am driving about 20 min, stop at a store turn it off, when i turn it back on its doing this. It seems simple. but since I am new to the car dont know where to start. I checked what I thought it would be.
avatar307
10-30-2004, 07:40 AM
Huh. Damn 92s. I put 150,000+ on a set of spark plugs, never missed a beat. They don't even look like spark plugs anymore... I keep them on my desk to amuse me. The filiment on several of them is burned clear into the insulator. The gap is like... .075 instead of .060. Never missed a beat, started right up and purred.
1994buick
09-22-2005, 04:28 AM
I see your old post (Below)...i am having shaking between 45 and 60 mph...in my 1994 buick lasabre. No one knows reason.
I'm told probable wiring problem ...fuel injector on #5 to PCM/// or replace the Power Control Module?
Did you solve your problem? What was it..
I hope you get this....
could reply to cmj777@sbcglobal.net
Thanks
QUOTE=92lesabredriver]hello all buick lovers... just bought a 92 buick lesabre custom tan/gold paint with tan leather nice car but.... it is idling rough and when i accelerate moderately not fast not slow just reg. when i hit about 1500 rpms it vibrates real bad and only stops if i punch it or let off the accelerator completely. i dont understand it no one ive talked to has ever heard of it. its not the axles or the drive train i dont believe. i think it has to be something with the fuel system or i dont know any suggestions would be much apreciated. and no the service engine soon light only comes on once in a blue moon for like 5-10 secs then goes out. so the mech. told me he cant get a code cause it doesnt hold it when the light goes out so im lost help me find my way.... JB[/QUOTE]
Thanks
patjr
09-25-2005, 01:57 PM
Hi,
I want to replace the fuel filter on my 92 lasbre but I cannot find it's location. Help?
patjr
patjr
spinne1
09-25-2005, 09:38 PM
Hi,
patjr
It is under the car, on the passenger side, behind the engine and in the curved part of the floor where the exhaust fits into. Basically a foot or so behind the firewall if I had to guess. You can't miss it. It is a large silver round thing with two gas lines attached to it. (When you get your new filter, DON'T pull of the plastic tabs off of each end of the filter--they are a vital part of the installation.)
patjr
